not connect agilent U2701A
Hello
I am writing a program to connect the Agilent oscilloscope U2702A to a computer using labview software.
I have written a basic program for connecting through IVI, which I have put for you below. This error is announced when I run the program.
Exception occured in AgilentU2701A.AgilentU2701A.1: AgilentU2701A: Failure cannot recover.
Software module could not be loaded from the IVI Configuration Store. in Untitled 1
How can I fix this error?
(2,021 Views)
Have you installed all the necessary tools and drivers?
Do you see your oscilloscope in NI MAX?
You should be able to communicate with the device through VISA Test Panel
(1,931 Views)
Hello
I installed two software drivers called
Agilent_USBDAQ_Setup_V2.01
driver_ivic_ivicom_AgilentU2701A_1_3_5_0
I also tested with NI MAX and R&S VISA software and the results are as follows.
(1,916 Views)
You don't mention how your are physically connected to the instrument?  GPIB, USB, LAN?
It could also be because you have multiple versions of VISA installed (NI VISA, Keysight VISA, R&S VISA, etc..) which seems likely if you have Agilent, R&S and LabVIEW installed.  Make sure you have the VISA setup as described in this reference.. https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHh0CAG&l=en-CA
Hope that helps,
Craig
(1,881 Views)
