Renaming NI USB-6525
I need help renaming a NI USB-6525 without using NI Max. If this isn't possible, is there a way to identify one NI USB-6525 from another without configuring it in NI Max?
I have multiple NI USB-6525 which I am going to deploy on multiple machines to data collect. The software I developed relied on identifying a machine based upon the name of the DAQ that I set in NI Max. The trouble is I need to distribute this software out to multiple machines that don't usually run LabVIEW. I don't want to have to setup Max and have to go to multiple DAQ's with every laptop and setup the names.
I notice in LabVIEW there are property nodes for Serial Numbers under the DAQmx Device. I was previously using the DAQmx System DevNames to get the device name when it was plugged into the PC. However, when I try the DAQmx Device Accessory.SerialNums I get an error -200220 Device Identifier is invalid.
Does anyone have any suggestions on how I can identify a NI USB 6525 without having to set everything up in MAX?
Thank you.
(1,525 Views)
So I googled it for you and came up with this link "How can I check the Serial Number of a Device using LabVIEW?"
You are on the right track of getting the SN of the DAQs. Keep in mind that you still need a method to associate the correct DAQ to the Correct function.
The other cmd you will be needing is listing the attached NI daqs (ask your friend, google)
Good luck.
(1,478 Views)
I appreciate this but I really should thank google shouldn't I. 😛
(1,474 Views)
