normal string to hex string
Hi all,
This question has probably been posed before, but I cannot seem to find a situation that quite matches the issue that I am experiencing. I have a numeric array that I flatten to a data string, reverse order, take the first two elements, reverse the order again, and feed the characters into a for loop. I want the string to be in hexadecimal, thus having FE0C (in hex) going through the for loop, but when I highlight the execution I see that normal display characters are going through instead. When I display my string, I have already right clicked to show the hex display which is correct. How do I convert the normal string to a hex string?
J
(5,109 Views)
You do not need to convert.  All you are commenting on is how the data is displayed.  THE DATA IS STILL THE SAME.
(5,106 Views)
Yes I do realize that. However; if you look at the attachment, the substring in the for loop is in normal display form and I wish to convert that to number. I cannot use the Hex to Number function as I have in the attachment. How would one change yoe into number?
(5,094 Views)
Accepted by topic author Jas.D
You could use Type Cast to change it to a U16 (since it is supposed to be 2 bytes) or Unflatten From String.
(5,089 Views)
Fantastic! It worked. Thank you so much!
(5,080 Views)
