no compile fpga
hi! I'm trying to compile this fpga, but the compile button doesnt show up and if I try to run it, it shows up a compilation on the local server but it continues forever on "translating".
could  someone help me please
(2,347 Views)
Hi alex,
What about using the "Create a build spec" option?
(2,345 Views)
I'm not understanding, sorry, what should I do?
(2,325 Views)
Hi Alex,
In creating an executable from your LabVIEW VI you usually first define a build spec(ification)! This option is available for host computer, RT target and FPGA target as well…
(And it is also shown in the image which you attached to your message!)
(2,317 Views)
yes I'm trying to do it, but now it's going forever on "estimating resources"..
(2,303 Views)
Hi Alex,
so you are able to define a BuildSpec? And you found the "Build" button when you open the BuildSpec?
When you need more help you could attach your whole project, nicely packed in a ZIP file.
(Or you may try the CompileFarm service provided by NI.)
(2,299 Views)
Accepted by topic author alex8624
Hi Alex,
Not a technical suggestion but I find myself stuck at that stage quite a few times. It usually happens for me after I cancel an on-going compilation and attempt to re-compile.
So I force quite the compiler and restart it then when I attempt to compile again, everything works fine after that. (Quit Immediately option).
EDIT: This is not a solution. But something if you would like to try.
(2,292 Views)
