nipalu.dll
I'm installing Labview 5.1 under Windows XP to be used with PCI-MIO -16XE-50 and NI-DAQ 6.9.3 to run an old aplication that was originaly developed in Windows 98.
After installing LabVIEW and ni-daq, when I place a DAQ vi in the diagram, i receive an error
"This aplication could not be initialized because NIPALU.DLL was not found. Reinstaling the application may correct the problem"
I've re-installed everything LabvIEW, NI-DAQ several times, it didn't worked.
Any help is more than welcome.
Ricardo
RKO
Message 1 of 8
(11,013 Views)
This is an old post!
¿But someone has the solution?
I have same problem in XP, LV2011.
Message 2 of 8
(9,894 Views)
Hi Edupo,
While NI DAQ 6.9.3 is compatible with Windows XP, it is not compatible with LabVIEW 2011. This link illustrates all of our DAQ and DAQmx drivers and their compatibility with past versions of LabVIEW. I would recommend upgrading your older VI to support the DAQmx drivers. Here is a good article that explain how to do this. The correlation is not exact between traditional DAQ and DAQmx, but I would certainly recommend performing the upgrade.
Warm Regards,
Tannerite
Message 3 of 8
(9,880 Views)
Thanks tannerite for the answer.
I not described my problem very well.
I'm developing in LV2011, W7 and DAQmx 9.5.5 for computers with XP and without LV. When I make the Installer I'm not including DAQmx and because of that I have an error with this file. Now I've solved the problem with this information.
Regards.
Message 4 of 8
(9,870 Views)
I'm developing in LV2011, W7 and DAQmx 9.5.5 for computers with XP and without LV, like you... How do you do to ? Please I need your help
Geoffrey, LabVIEW Associate Developer
Message 5 of 8
(9,761 Views)
In my case I make an installer selecting on the "Adittional Installers" menu the "NI-DAQmx Core Runtime 9.5" This install the library and make my app to work.
You only need to make the installer once and then you can only copy your app *.exe
Hope it helps to you.
Message 6 of 8
(9,756 Views)
Hi to everyone!
I've just wanted to launch NI Update Service 2.3 because I noticed that for a while it didn't appeared so I launched it and a warning appeared telling me that NIPALU.dll wasn't found in the system.
I tried to repair it going to Programs and Characteristics/Software National Instruments -> and choosing the program you want (in this case the updater) but when a submenu from NI appeared displaying me three options, I chose the Repair tool but it didn't work. So I investigated...
I read in other forum (http://lavag.org/topic/17917-avast-deleted-nipaludll/) that a possible cause for this mistake may be the new version of Avast! Antivirus' trunk. And, for my case that was the problem: The new version of Avast had retained in, the file NIPALU.dll thinking it may be a virus.
Baúl de Avast
Then, you just select the file and make it a "Global exception" for avast! to always ignore it and stop thinking it's a harmful file (before you perform all of this make sure you have NI Update Service closed). Then, you just open it again and you're done!
Message 7 of 8
(8,320 Views)
I had the same problem (nipalu.dll)  updating  NI SCOPE. I solved my problem by simply restoring the sytem.
Message 8 of 8
(7,177 Views)
