01-22-2014 08:38 AM
it didn't work after repairing LabVIEW nor DAQmx, but it is ok now after repairing NI VISA...
thanks.
Adeline.
01-23-2014 05:40 AM
The same problem. LV2011, Avast Pro (Institute subscription). It has aleady deleted for last few months: niarbk.dll, nidmmk.dll, niSTCk.dll, APC driver (not NI) and now NIPALU.dll. Before I could find the files in the "virus chest". I chose "scan again" - no viruses. Good. When I restored them, Avast deleted them again. I reported them fiiles as faulse "positive", I wrote them several times - no response.
Now it is worse - NIPALU.dll is not in the virus chest. Sometimes Avast deletes files without any comments.
I do not see any other solution than to never use Avast - it's incomatible with NI software.
P.S. One more comment about Avast. It did not see a virus called something like BAT.killer.trojan 6 years ago and still does not see it - be careful.
01-23-2014 07:42 AM
I was in the same case after Avast deleted nipalu.dll last Monday (re-installation of LabVIEW and DAQmx didn't solve the problem).
But repairing NI VISA using Windows Control Panel / Uninstall or change a program was the good solution for me.
Thanks a lot!
Herlock
01-23-2014 11:57 AM - edited 01-23-2014 11:58 AM
Also had this problem. Copying nipalu.dll from another machine as that'll be quicker than a repair. Hoping this will fix it. Uploading the dll for anyone else who wishes to do the same.
Using Labview 2010 full development, win XP (and avast...for now).
02-02-2014 03:33 AM
Thank you for sharing the file. Have the same problem & also Avast.
I notices that googling "nipalu.dll missing" sends you directly to websites that do not seem very trusworthy.
( like helpcomp.com offering a missing dll fixer?)
02-02-2014 04:38 AM
I put the nipalu.dll from marc1uk into my C:\Windows\System32 directory of my windows 7 ultimate computer.
That was not a good idea: This dll is not made for my operating system.
Though now labview does start up, it does not close any more.
I cannot delete the nipalu.dll because NI device monitor is using it.
Could anyone share the nipalu.dll that should have been there before avast took it away ?
02-02-2014 11:30 AM
Though I am not entirely sure if just replacing the nipalu.dll didn't work for a different reason,
it is now solved. I reinstalled the daq-mx device drivers (1,5GB)
http://www.ni.com/download/ni-daqmx-9.8/4297/en/
thanks we have this forum
02-03-2014 09:20 AM
I just wanted to let everyone know that Avast! verified that nipalu.dll was removed from their virus database, so Avast! should not continue to delete this .dll. If you see this occur again with an updated version of their virus database, please let us know!
02-03-2014 09:24 AM
Also, we definitely recommend replacing the .dll by running a repair on your NI drivers, rather than exchanging .dll versions online. This is the best way to assure that you get the correct version for your system.
02-03-2014 09:34 AM
Indeed. I confirm both 😉
