nilvaiu.dll error robotics starter kit 2.0 9632 labview 14.0
Hi:
I appreciate all the support this site has given me.
I am trying to run a small VI that will read the motor encoder.
I get the error msg DAQmx Clear Task.vi loaded with errors on the target was closed     &
milvaiu.dll:daqdestroytask110:D. Ensure the library is present on the RT target.......
I looked on the web and was given the info to reinstall ni-daqmx 14.0. which I did several times and I still get the error.
Have any suggestions?
(2,769 Views)
The robotics kit uses a NI sbRIO-9632 embedded controller. You cannot use NI-DAQmx on a RIO system - it is two different drivers for two different platforms.
You will need to use the NI-RIO driver instead. You can refer to the LabVIEW 2014 Robotics Module Help for examples and explanations of how to write code for the sbRIO-9632.
Steven Gloor
Staff Customer Engineer - CTA, CLD
(2,726 Views)
