ni::dsc::osdep::PosixError when starting labview
Hi
When I try and start Labview i get the following error
terminate called after throwing an instance of 'ni::dsc::osdep::PosixError'
  what(): Invalid argument
Aborted
we have version 9.0 of labview on linux rhel 5.4 and from what i can see from the gui it get's up to running "converting toolkits" before it crashes.
Caleb
Message 1 of 10
(3,824 Views)
Is this after a new installation, or on a system that had previously been working properly?
Message 2 of 10
(3,820 Views)
this is on an installation that worked before for me and still works for others.
Message 3 of 10
(3,812 Views)
calebbaker,
Try reinstalling LabVIEW and see if that fixes the problem. You'll want to remove any toolkits and modules during the reinstallation process and make sure you add them only after LabVIEW is working properly.
Cheers,
KyleP
Message 4 of 10
(3,799 Views)
I cannot re install labview as other people are still using it, I've tried using their .bashrc files with no luck, I've also cleaned out all of the files in my home directory to hopefully become a clean user but this didn't work
Message 5 of 10
(3,789 Views)
Are you installing from a disc? If so, go to ni.com/src and try downloading LabVIEW 9.0.
KyleP
Message 6 of 10
(3,778 Views)
What happens if you create another user account?
Message 7 of 10
(3,771 Views)
When I try and start Labview i get the same error
"'ni::dsc::osdep::PosixError"
I launch labview as root and It works.
Why ?
Presently I wait for the answsers with
grep -r "'ni::dsc::osdep::PosixError" *
Cheers,
jo
Message 8 of 10
(3,745 Views)
After re insatlling labview I get always this error :
"terminate called after throwing an instance of 'ni::dsc::osdep::PosixError'
what(): Argument invalide
Abandon"
jo
Message 9 of 10
(3,733 Views)
After rebooting it works without errors.
Strange...
jo
Message 10 of 10
(3,728 Views)
