delay signal
My purpose is to simulate an impulse generator, and i have some problems with the double impulsions.(see the first attachment)
I want to delay a simulation signal, and i need to settle this delay.
At the begin i try with the Y[i]=X[i-n] VI.vi and that work but it is impossible to settle it in time.
So i downloaded the control simulation toolkit and I try to use the simex  transport delay.vi It look like fine, but I can't import it in my project same if i try to transform it in subVi. (see the second attachment)
If you have another idea,I will be happy to see it.
Could you help me please ?
(3,831 Views)
Accepted by topic author Marc.M
If your delay is in fractions of samples , no problem
If not, you can do it with a filter.
Here is a simple echo program using convolution (also in fractions of sample rate)
Greetings from Germany
Henrik
LV since v3.1
(3,820 Views)
I sense another homework problem.
(3,807 Views)
Right, should have posted the picture 😉
Henrik
LV since v3.1
(3,801 Views)
Hello, at smercurio_fc ->Wrong, I'm in intership and I never touch labVIEW before to start my project and my tutor dosen't know very well labVEIW.(He advice me to do a post on this forum)
At Henrik Volkers -> thank you very well for your help. But I don't know how repeat your solution indefinitely. Do you have any idea ?
Greetings from Roumania
Marc
(3,783 Views)
Please provide more details:
What are you receiving? An array of data? A waveform? What timing informations do you have?
Still wonder why the delay.vi doesn't fit your needs...
Henrik
LV since v3.1
(3,767 Views)
I'm sorry to answere so late.
I was very busy and i forgot to answer. I managed to adapt your program at my needs, so thank you.
If you want I can share my program(impulse generator) on this forum.
Greeting from Roumania,
Marc
(3,749 Views)
