newbe help with understanding order of execution and timing
natas,
here's my pseudocode. It's not perfect. parallelism makes this harder I guess.
loop{
turn green LED ON
turn red LED OFF
ledBool= !ledBool
if (ledCount  == 1){
    turn yellowLED  ON
    delay 5 seconds
    turn yellowLED OFF
    flash orange LED 10 times (eat up 5 more seconds)
    turn greenLED OFF
    turn redLED ON
    flash ornageLED 4 more times
else
    delay 10 seconds
set greenLED OFF
set redLED  ON
delay 10 seconds
Message 11 of 19
(1,881 Views)
Sorry for sounding so daft, but I can do this with only one loop? I'm seriously running out if ideas guys.
Message 12 of 19
(1,875 Views)
Wow breakthrough, I think I might have it. Don't give me an answer yet, please. haha
Message 13 of 19
(1,866 Views)
Finally! This seems to work pretty well. I couldn't do it with just one loop, but close. Any advice on how to make this more efficient would greatly appreciated.
Thanks guys!
Message 14 of 19
(1,857 Views)
Now go back and look at the spoiler in my last post.
NOTE: there is a missing wire!  left for the student to debug
"Should be" isn't "Is" -Jay
Message 15 of 19
(1,848 Views)
Thanks Jeff I didn't even see that there. Not sure what the arrows pointing backwards do. Looks kind of like an op-amp in a feedback loop. I'm going to try out your circuit   program (haha) and see how it differs. Is there a reason why yours is better than the one I made?
Message 16 of 19
(1,825 Views)
Those backward arrows are "Feedback Nodes."  They are found on the Structures pallete. They operate simillar to Shift Registers (The differences are moot for this use case.)  In fact, you could right-click them and select "Replace with Shift Register" and have equivalent code in this case.
@as to "Better" there is one HUGE difference.  Your vi must complete the for loop meaning, it could take up to 40Seconds afer the "Stop" button is pressed before the vi actually stops.  Most users are going to pound their mice agressively when that happens.  My vi will exit within 1/2 second (Honestly, this is STILL too long! ideally we should use @ a 200mSec wait and adjust the Q&R divisors accordingly)
Getting familliar with all of the functions on the pallates takes time and practice.  Nice work.  Read the help in the floating window (Hit Ctrl+H to bring up the help window) and don't be afraid to keep posting.
Message 17 of 19
(1,818 Views)
You can remove the inner For loop and use a Quotient and Remainder of the remaining While loops "i" to get your "loop# 1 to 40".
That way you'll also get a Stop response time of <1sec.
Good job.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 19
(1,795 Views)
A funny thing happened on the way to school:
Although the OP learned a lot and made great efforts!  I did not read and understand the specifications in the first post.  Hence the proposed solution in message 10 ABSOLUTELY missed.
This is my fault for not following a clear spec!  Post 10 is hereby revolked of its solution and an alternate snip is below
Message 19 of 19
(1,773 Views)
