.net objects in code, DLL and portability
Hi
Does any one know if there would be any portability issues when converting LabVIEW code containing .NET objects into DLL? The DLLs would be distributed most likely across Windows 7 and 10 desktops. For example, do the targets need to have specific run time engine of .NET? I am not familiar with .NET but I would imagine that if I would like use .NET methods I would need to make sure that targets have the minimum version which is stated in MSDN?
(3,029 Views)
Accepted by kretinga
Hello kretinga,
I can only answer your questions partially:
  • .NET is downwards compatible up to a certain degree. Functions introduced or changed in an newer version will not work with an older version.
  • .NET is installed with Windows by default. E.g. .NET 3.5 is installed on Windows 7, 4.5 on 8, 4.6...4.7.2 on Windows 10. See this table for detailed information: .NET Framework versions and dependencies
  • The "minimum" version you are aiming for is either 3.5 (as pre-installed with Windows 7, and available up to current Windows 10 v1809), or 4.7.2, as this is pre-installed with Windows 10 1089 and available down to Windows 7.
Does this answer your question a bit?
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(2,992 Views)
Thank you, this has been very helpful
(2,984 Views)
Thank you for reporting back. Good to know I could help 🙂
CLADMSD
(2,968 Views)
