.net event crashes with Windows 7
I am using an internally developed .net assembly to communicate with some proprietary hardware.  I developed an app in LabVIEW 8.6 and Windows XP which worked as expected.  When I moved to Windows 7 / LabVIEW 2009 I get a crash whenever an event fires.  The dialog that is fired shows "Assertion Failed" and has Abort, Retry, Ignore.   Abort closes LabVIEW.  I have attached a screenshot of the dialog.
I made a very simple test vi, which registers the event.  When then event fires, I still get a crash.
Any ideas?  This same concept works in C# with the following code:
using Crestron.ActiveCNX; namespace WindowsFormsApplication4 { public partial class Form1 : Form { public Form1() { InitializeComponent(); ActiveCNX cnx = new ActiveCNX(); cnx.onSerial += new ActiveCNXEventHandler(cnx_onSerial); cnx.Connect("192.168.0.30", 3); } void cnx_onSerial(object sender, ActiveCNXEventArgs e) { MessageBox.Show(e.SerialValue); } } }
Thanks in advance,
John
(3,012 Views)
Accepted by topic author jpsc
(2,989 Views)
Hi John,
Thank you for posting the solution to this thread--it will help others who find this forum find their answer.
Cheers,
Marti C
NI Medical
(2,959 Views)
