Can Citadel save and display a DSC Array? Single variables are ok...
Hello All:
Citadel works well when saving data from individual shared variables
that were created using DSC. I could see the variable update on Citadel.
When these shared variables were changed to a single Array[32]
I do get the correct values on my hardware but
can not see any of the variables on Citadel...database...
I'm using Labview and DSC 2009
By the way I made sure the array is ok as shown here A300001L32
any suggestions...?
thanks,
\\carlos
(2,561 Views)
Carlos,
You can save arrays of data into citadel, but trace views consider array data a complex datatype(variant) and cannot be displayed. However, if you were to read the data using read traces.vi and specify the variant type, you will see that your array data is indeed stored.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(2,533 Views)
