.net constructor nothing show up
I don't remember installing anything from Cognex.  Is there a way to check.
Kudos and Accepted as Solution are welcome!
Message 11 of 23
(1,938 Views)
You should be able to check under Control Panel>> Add or Remove Programs. If you don't see anything installed from Cognex, then you shouldn't have any of their software installed. They are a machine vision company, so if you do not do image processing, then it is likely that you do not have their software installed.
Just to clarify, you are no longer having issues with your .NET assembly, right?
Best,
Dan N
Applications Engineer
Message 12 of 23
(1,922 Views)
I am still having the same problem.  Please help.
Message 13 of 23
(1,917 Views)
I apologize; from earlier in the forum, I thought that you had reinstalled .net support and then were able to successfully use it in Labview. What version of Labview are you using?
Best,
Dan N
Message 14 of 23
(1,907 Views)
I'd also suggest doing a repair on the LabVIEW install, or as a last resort a full uninstall and reinstall. It's amazing how many problems this fixes. Does the same thing happen on another machine?
Message 15 of 23
(1,904 Views)
I am using LabVIEW 2011.  I also have LabVIEW 8.6 on my machine.  However, LabVIEW 2011 is the one having problem with .NET.  In the "Select .NET Constructor" dialog, there is a browse button.  Maybe I can browse to the correct .NET classes?  How do I do that?
I want to save the re-installing labview option at the end.
Message 16 of 23
(1,898 Views)
I followed the instruction on http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/configuring_clr_version/, and the now it works.  If I do this, I will be using CLR 4.0.  It seems LabVIEW recommand CLR 2.0.  How do I use CLR 2.0 instead of CLR 4.0?  Thanks!
Message 17 of 23
(1,893 Views)
Accepted by jyang72211
If it were me I'd click on the button that says "Browse...". But that's just me. I'm funny trying the obvious things.
If it were me I'd change the Framework version in that file in the line that says <supportedRuntime version="v4.0.30319"/> to the 2.0 version. But that's just me. Look in the "C:\Windows\Microsoft.NET\Framework" directory for the ones that are installed.
Message 18 of 23
(1,891 Views)
haha.  I did try the browse button, but I didn't know where to browse.  I change the line in the file to  <supportedRuntime version="v2.0.50727"/>.  When I drop a constructor node on a block diagram, LABVIEW will exit/crash.
Message 19 of 23
(1,888 Views)
I think you have a corrupted installation. Creating that configuration file is only necessary if you explicitly use a specific version of .NET. Without that file placing a .NET constructor on the block diagram should pop up the constructor select dialog with all of the assemblies in the GAC listed. The Browse button is used to select a private assembly.
Message 20 of 23
(1,884 Views)
