need some help with saving VIs in LabVIEW
I finally got the LabVIEW Student Edition to work on win XP.I have all my VIs developed in Labview 6.1.I am not able to open it in 6.0 and don't have access to 6.1 either.(I guess I did not save it with options in 6.1).Can someone help me out with this?
thanks,
sujani.
Message 1 of 9
(3,445 Views)
You have big problems because LabVIEW is not backward compatible, which means anything written in 6.1 will never, ever run in 6.0.3. This is very stupid, but the guys at NI want you to have to buy the new releases so they can stay employed.(Maybe ?).... I think you can download the upgrade or you will have to rewrite all your VIs. Sorry.
Tim Burroughs
email:tburroughs@labratsengineering.com
email:tburroughs@northropgrumman.com
Message 2 of 9
(3,445 Views)
How many VIs do have to convert? I don't mind converting a handful. Attach what you need converted.
Message 3 of 9
(3,445 Views)
6.1 is capable of saving to a previous version (6.0). The exception is 6.1 specific features like the event case.
Message 4 of 9
(3,445 Views)
That's kind of a harsh statement against NI. VIs can sometimes be saved for
previous versions, and the original poster's question isn't hopeless.
Check out File -> Save With Options. There is a save for 6.0 option
available. Some structures clearly wont translate to previous versions; for
example the event structure is new to 6.1 and didn't exist in 6.0 so that
particular feature could never be backward compatible. However basic code
saves fine for previous versions.
Going back major releases (for example to 5.x) is indeed more of a
difficulty. I can understand the logic of not messing with a working
installed system, but I haven't used 5.x for new development in years.
There's so little call for 5.x anymore.
FYI - If you haven't checked out 6.1, it i
s lightyears ahead of 6.0.x with
the event structure, XML, activex, windows XP support, and so on. Other than
the expensive pricetag (and student/eval versions), its hardly worth
thinking about 6.0.x anymore.
-joey
"Tim" wrote in message
news:50650000000500000071CA0000-1042324653000@exchange.ni.com...
Message 5 of 9
(3,445 Views)
hi all,
thanks for all your responses.I am quite aware of 6.1' advantages over 6.0.but right now i am a new grad looking for jobs in labview-i cannot afford to install the labview development version at home:).i did not foresee this problem when i was working,and had a chance to use 6.1 and did not save my vi with options.i guess i will have to rebuild them all.
sujani
Message 6 of 9
(3,445 Views)
hi,
here are the VIs.i know they are really big,especially a few VIs.If it takes long time,just forget it.Anyways,thanks a lot.
Message 7 of 9
(3,445 Views)
Sujani,
Here are the VIs saved for 6.0. I hope I didn't miss any, so if there are some I did, just post those VIs again.
I've put all of your VIs in one llb, and left the instrument driver VIs in their own llb.
Zvezdana S.
Message 8 of 9
(3,445 Views)
hi,
that was really great!thanks a lot!
sujani
Message 9 of 9
(3,445 Views)
