need help with Hipot test
Hi everybody
is there anyone work with Gaurdian 1000 series Hipot test ?? I need some assistanse
I have some proplems there is delay when I get data from device .
Message 1 of 10
(4,544 Views)
What does your VI look like?
Jim
Message 2 of 10
(4,536 Views)
We would need to see the VI or have additional info in order to try to help you.
Message 3 of 10
(4,530 Views)
Hi
Attached is my Vi
The problem was when I run the test I get the data but for example it has gave me Device Name reading in Voltage reading field , sometime it gave me Real current reading in Voltage reading filed , testing wihle reading in real current reading filed and so on .
I could not get data in right place
thanks
Message 4 of 10
(4,511 Views)
Does it work if you step through the program.  It sounds like your program might be sending commands and not waiting long enough for the Guardian to respond, then sends another command and receives the response from a previous command.
Jim
Message 5 of 10
(4,499 Views)
yea , I think this was the problem
I tried to put 2 second waiting between commands ,but still I face the same problem .
should I do some setting for device to be more quickly?
Message 6 of 10
(4,495 Views)
General comment on the code:
You should avoid using the flat sequence structure and use the error cluster and VISA reference in / out for the data flow (sequence).
HiPot tester:
Is there a command that will tell the program that the last command was complete?  Or would it return a value like 0 or -1?
Otherwise, relying on a fixed delay may not be reliable.  Using a large delay would unnecessarily slow down the application.
Message 7 of 10
(4,487 Views)
there is no command  to tell the program that the last command complet , but I will use time , there is specific time to stop the loop  .
about error cluster function , actually I do not know how can I use it inside sequance , can you show me example about it please .
Message 8 of 10
(4,480 Views)
First step is to clean up the code.  It should look something like below:
You can create a sub VI for your delay or a subvi which contains both the VISA write preceeded by a delay (better).
Get rid of all the flat sequences (as in the code snippet above).
The best approach would be a State Machine, but that advice may be a bit premature.
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
There are other tricks to cleanup / improve the block diagram, but we can get into that later.
Message 9 of 10
(4,465 Views)
thanks for helping
Message 10 of 10
(4,455 Views)
