myRio-display
I am using Labview 2017 and I am trying to display numbers on the 7-segment LED display. Unfortunately, I keep getting the same error but I am not sure what is exactly causing it. The error is: SubVI 'Digital Output9': SubVI is not executable. Please check the attached document.
Any suggestions?
(2,463 Views)
I see that you are using trying to use Connector A of myRIO. The error can be because of multiple reasons.
- Try running any myRIO example projects involving DIOs. If it is working, very good.
- I understand that you have used Digital Output express VI. Only one Boolean can be given as input. Correct me if I am wrong.
- Please attach the project/VI if possible to get a clear understanding.
Rahul
**** KUDOS IF IT HELPS :+1: ****
(2,398 Views)
