myRIO and ADIS1620X Inclinometer
Hi All
I'm attempting to interface a ADIS16203 Inclinometer to a myRIO via SPI, its part of a prototype I'm developing for a client.
http://www.analog.com/media/en/technical-documentation/evaluation-documentation/ADIS1620x_PCB.pdf
http://www.analog.com/media/en/technical-documentation/data-sheets/ADIS16203.pdf
There is example LabVIEW and FPGA code for a cRIO unit here
http://www.ni.com/example/31265/en/
However I'm attempting to use the myRIO SPI express vis to implement the coms to the Inclinometer, however no luck so far.
I could go down the road of converting the cRIO code to myRIO code but if someone has some myRIO express code or could point me in the right direction I would be very grateful.
Thankyou
(2,599 Views)
Hi KurtFriday,
After further research I do not see any express code that could be used with your myRIO, so it may be best to convert your cRIO code to myRIO code.  When moving from a cRIO to myRIO it will be important to consider I/O specs of each of the devices, as is reinforced int the following link:
Moving from cRIO to myRIO:  https://forums.ni.com/t5/Academic-Hardware-Products-ELVIS/Moving-from-cRIO-to-myRIO/td-p/2920632
Chris B.
(2,555 Views)
