Micro Grid Simulator in Labview
Hi Guys , i need a Help i want to make a Simulator of Micro Gird Energy Management System (Wind+ Solar+Diesel) Generation, without any hardware connection so it just basically a test model , for Energy Management System
Message 1 of 11
(7,059 Views)
That's a bit vague... what exactly do you want to do?
Message 2 of 11
(7,046 Views)
Have you seen the resources available here and here?
Message 3 of 11
(7,045 Views)
i agree with you that bit vague i just want to simulate , for example .. wind is generating 6 M.W , and solar is generating 12 M.W , and diesel is generating , 3 M.W i just want to show there generation in Scopes and , some of the load is connected with them , i the load's get High , these system precicesly adjust there self with generation or , you can call in short Centralized Energy Management system but with all dump values that means no Real Wind Turbine or Solar or Diesel Generator is connected by Labview
Message 4 of 11
(7,035 Views)
Thanks for the Help brother but i am new in Labview and i just need that fast , i really appreciate what you shared but all i need is to create Centralized Energy Management System ,  with some Input values .. thats all
Message 5 of 11
(7,034 Views)
I think you underestimate your task... you'll have to mathematically describe the interaction between the different power supplies and implement that in LabVIEW. However describing such a system is not something which is done 5 minutes.
Message 6 of 11
(7,029 Views)
i agree with you brother but the thing is can you help me out ? in this .. its not easy .. ! but i am realtively .. happy if you can help me in some where ..
Message 7 of 11
(7,027 Views)
Get the control and simulation toolkit and with the help of the LabVIEW tutorials that I'm sure you have time to take, post back when you get stuck and have a specific question.
Message 8 of 11
(7,015 Views)
I will ..but still some help appreciated 🙂 ..
Message 9 of 11
(7,003 Views)
I am also interested in this,is there anywhere I could find mathematical models of diesel generator, solar or even complete smart grids?
Message 10 of 11
(6,534 Views)
