myRIO Optical Encoder express VI Angular position and speed.
Hi, I am a systems engineer student and I would like some help on acquiring angular position or shaft postion from an encoder connected via myRIO. From using the Encoder express VI, I am able to get the counter values and counter direction. Is it just maths that I need to be able to calculate the shaft position? The encoder I have has 1024 cycles per revolution (CPR).
I have searched how to do this, but can only find how to do it with a DAQ assistants, which has the option to measure linear or angular postions. Does myRIO have similar express VIs to this?
(4,380 Views)
Hi there,
Having a quick think about this, to me using this could work -
Feed counter value into the quotient remainder function, then take the remainder and feed that into the below equation.
Counter Value => Quotient Remainder function  => (Remainder/1024) * 360  = position in degrees.
What are youur thoughts on this?
Scott
(4,282 Views)
Thanks. How about the speed calculation by the counter value in this case?
Rui
(3,701 Views)
