my vi is writing just the same data into spreadsheet even after changing the loop iteration time. hw can I change this mode ?
My VI is writing the same amount of data into spreadsheet file even after changing the for-loop iteration time
Message 1 of 12
(2,898 Views)
Could you futher clearify? How is the loop iteration time affecting your data? Please post vi or .jpeg of it at least.
Message 2 of 12
(2,891 Views)
I have 2 as the number of times the vi should run, it actually write data into spread sheet. But after changing the 2 to 4, ( making the for loop to run 4 times), it writes the same data the 2 times wrote into spread sheet. I have attached the vi
Message 3 of 12
(2,872 Views)
...I have also attached the spread sheet file. The vi is writing the same data into spread sheet, regardless of the number of loop iteration.
Message 4 of 12
(2,868 Views)
Message 5 of 12
(2,862 Views)
Your attachments are not making it through.
Instead of waiting to see the code, let me blindly guess that you have an autoindexed array input to the Loop which is two elements long so the loop spins twice regardless of what you wire to N (unless you wire 1 or 0).
Message 6 of 12
(2,858 Views)
That could be the problem. Anyway,I have been struggling with this issue for quite a while now.I can attach and resend the vi to an email address if you could provide one or make print screen, so that you could have a close look at it. If that is the road map the solution of the issue.
Message 7 of 12
(2,851 Views)
You should post the VI (with appropriate values saved as default) to this thread.  (At least a JPEG or PNG screenshot).
Inside the For Loop, right-click on the N terminal and create Indicator.  Run the VI and you will see how many times the Loop spins.
Further guessing:  You may have a 2D array with two rows and many columns feeding the For Loop.
Message 8 of 12
(2,846 Views)
I just don't know what else to do
Message 10 of 12
(2,821 Views)
