How do I get a digital out task to only generate port 0?
HI;
I have a VI into which I feed a DO 9476 task. When I created the task, I selected port 0 (which was the only option). When I run my VI, I get an error that tells me I'm looking for 8 bits yet the task feeds in 32.
See the attached VI and error screen shot.
Any ideas?
Thank you,
(2,482 Views)
Accepted by topic author 4BoysDad
4BoysDad,
It seems you are trying to output to the port (which has 32 lines) instead of a collection of lines.  When you create the task, instead of choosing Port Output, choose Line Output, and select the 8 lines you would like to write to in the next dialog (shown below).
Drew T.
Camber Ridge, LLC.
(2,461 Views)
