my project is to measure ac voltage and current using lab view.
Dear Sirs,
                I have a project to measure ac Electrical parameters such as current, voltage, power factor etc. through data aquisitioin with labview. Can I do that ?? If yes then kindly help me with some opinions and ideas. I shall be highly thankful to you.
Muhammad Hanan Azam.
Student of University of Engineering and Technolgy, Lahore, Pakistan.
Message 1 of 19
(4,369 Views)
Yes it is possible. This can be acheived through serial communication. Read about serial communication like VISA, VISA configure, VISA wite, VISA read etc.
Read about the serial communication of device with you are going to communicate i.e. some communication document etc.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 19
(4,365 Views)
Do I need mydaq device for that ?? If no then can it be done with mydaq? or which will be better?
Message 3 of 19
(4,350 Views)
What is mydaq?
--Ranjeet
Message 4 of 19
(4,346 Views)
Message 5 of 19
(4,339 Views)
Depends on your requirement
--Ranjeet
Message 6 of 19
(4,335 Views)
You want to measure the ac voltage and current using labview from which device ?
--Ranjeet
Message 7 of 19
(4,331 Views)
I do not know which device will serve my purpose. Thats why I want to know that what device or method I should choose.
Message 8 of 19
(4,322 Views)
I went through the link you provided and I think that is best for you becasue it is made for students with lots of advantages.
--Ranjeet
Message 9 of 19
(4,318 Views)
But I need it confirm that my task can be done by that device because it is very costly and I m not a professionalist.
Message 10 of 19
(4,315 Views)
