キャンセル
次の結果を表示
次の代わりに検索
もしかして:
my daq 6008 wil not drop the 5V after the VI is stopped, i have a digital signal going from the error out on the daq in the while loop to the error in on the daq outside the while loop and a boolean going to the data of the daq outside
my daq 6008 wil not drop the 5V on a digital output after the VI is stopped, i have a digital signal going from the error out on the daq in the while loop to the error in on the daq outside the while loop and a boolean going to the data of the daq outside, but i can t seemto get it to work
0 件の賞賛
メッセージ1/4
2,427件の閲覧回数
Can you post your actual code. You should also know that most people will give you a hard time about posting a word docunment on this site. You should post a picture in PNG or jpeg format (no BMP). If you post your code I will see what I can do to help you.
Post the actual VI
Tim
GHSP
0 件の賞賛
メッセージ4/4
2,383件の閲覧回数
