my daq 6008 wil not drop the 5V after the VI is stopped, i have a digital signal going from the error out on the daq in the while loop to the error in on the daq outside the while loop and a boolean going to the data of the daq outside
my daq 6008 wil not drop the 5V on a digital output after the VI is stopped, i have a digital signal going from the error out on the daq in the while loop to the error in on the daq outside the while loop and a boolean going to the data of the daq outside, but i can t seemto get it to work
(2,431 Views)
Can you post your actual code. You should also know that most people will give you a hard time about posting a word docunment on this site. You should post a picture in PNG or jpeg format (no BMP). If you post your code I will see what I can do to help you.
Post the actual VI
Tim
GHSP
(2,387 Views)
