multiple tasks in daqmx
I have project where I use 2 AO and 4DO to generate some predefined signals and  2 AI to acquire response. When testing only one sensor this works fine. In future I will have to test aditional sensor concurrently to the first one. User can start fitst and secould slot whenever he wants.
I can't create 2 AO tasks at the same time using only one PCIe card. I can;t combine all AO from slot 1 and slot 2 into one task becaus test on slot 1 has diffrent frequency (defined by user when other slot i running), amplitude and is started by user at  different time.
Do I need to buy additional PCIe card to run test on slot 2?
(4,282 Views)
If you want to run at seperate sample rates, you'll need seperate cards because that's the only way the hardware timing can work.
A workaround could be for you to sample at a rate faster, or equal to, the fastest that you would want to sample either slot and then average down to a lower sample rate based on your needs.
Example:
Sample all channels at 1kHz.
Slot 1 uses channels 0-7 at 1kHz, Slot 2 uses channels 8-15 at 2Hz.
The application is continuously using the data for slot 1 at 1kHz and throwing away the extra channels. Slot 2 picks up the extra channels when needed and down-samples to desired data set.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,264 Views)
This might be a good place for cDAQ.  Your main problem here is the different sample clocks.  Once the Analog Output clock is being used by 1 task, another AO task cannot use it.  So you will need to use another card.
(4,262 Views)
(4,221 Views)
Thanks for reply. In my project signals that I generate have low frequencies - up to 1kHz
With one slot I worked with finite samples like that:
Here are my 2 signals, first one has 1kHz, secound has 1 Hz. I can say that maximum frequency for signals will be 1kHz,then logical step is to resample all signals to that frequency
And then I need to generate in continious mode without regeneration? I will need to move this large signals into buffer in smaller parts?
I attach example how this concept looks now with some questions
When using cDAQ I can run up to 3 concurrent AO tasks?
http://digital.ni.com/public.nsf/allkb/5E0B829E50ADE1BC86257AC50062B2D2
Thanks in advice.
(4,213 Views)
Cant; edit previous post. I am wondering if I can do read and write in one loop. It would be much simpler and effect is the same
(4,201 Views)
