multiple results
Hi All,
I have a question about how to report multiple results. Here is my setting:
  1. I have 2 test
  2. I want to report the result of test 1, test 2, and total of test1+test2
Please see my attached VI
Thanks in advance,
Message 1 of 12
(4,808 Views)
I don't see what your question is.  Doesn't something not quite work they way you want?
Message 2 of 12
(4,806 Views)
My question is how to report multilple results such as the total of T1+T2 or the product of T1*T2, etc..Yes, my VI does not work the way I wanted.
Message 3 of 12
(4,798 Views)
I'm thinking that I need to save the result of test1 and test2, then recall them back to do any cases that I want, but I don't know how at this point.
Message 4 of 12
(4,782 Views)
Accepted by CP_AT
That would be because you need some getting started training.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
The basic problem is that there are no memory elements (Feedback Node or Shift Register) to hold the data from multip[le runs
If you select "Test 1" the default data for "Test 2" (a ZERO) is output from the first case structure.  Vice-versa if you select "Test 2"
A pair of Feedback nodes wired through the case structure are needed to "Remember" the last test value.
Somethimg like this would work much better
attached  in 2011
"Should be" isn't "Is" -Jay
Message 5 of 12
(4,774 Views)
I think the two enums need to be inside the event, else you get  a stale value of the control that fired the event. The terminal got read at the start of the iteration and that's all you get from the tunnel when the event triggers. Once the terminal is inside the event, it will get read once the event has fired and the new value is now available.
There is also the problem that the initial result is not displayed until there is a value change in a control.
Message 6 of 12
(4,744 Views)
Hi Jeff,
Thanks for your help.
Feedback nodes is a key to crack my head. I already thought about Shift Register, but it did not work out.
Message 7 of 12
(4,673 Views)
Thinking about shift registers should always work. Implementing them in LabVIEW requires understainding of them. Show us what you tried and we explain what went wrong. 😉
Message 8 of 12
(4,665 Views)
Here's a simple shift register implementation (LabVIEW 2011).
Message 9 of 12
(4,655 Views)
In my real case, I can't use the loop, so the shift register does not apply to it. Truly, I appreciated all your enthusiasm to help out the labview users.
Using the forums is the best way to learn and understand the meaning of each element because it’s real problem, real guru. Fun to learn this way!
Message 10 of 12
(4,641 Views)
