multiple remote front panels?
I have two separate applications running with remote front panels from this KB:
How can I use Remote Front Panels with Executables?
I can not get the two to run at the same time.  I was then shown this:
How can I run Two or more Executable with remote front panels?
This seems to be a little old (Version 8).  I am running 2012.
Has anyone gotten this to work?  How do you set up the web server to listen on more than 1 port?  How do you then direct that port to a particular app?
(2,686 Views)
For those who run ino the same issue: in the niwebserver.conf file that is created with the executable, in the section "Global Directives", change the "Listen 8000" to some other unused port and then rerun the exe.  Then call up the web page as usual but now using the new port number.  Since each app has a different "niwebserver.conf" file, each app can have its own port number.
Todd
(2,640 Views)
Thank you for the solution Todd. I was having the exact same problem. 🙂
LabVIEW 2013 SP1
Windows 7 64bit
Windows Server 2012 64 bit
Windows 8.1 32 bit
(2,522 Views)
