multiple processors
Does anyone know how to use more than 64 logical processors in a parallel for loop?
(995 Views)
You can set a line in your INI file:
ParallelLoop.MaxNumLoopInstances=256
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Support-more-parallel-instances-in-the-parallel-FOR-l...
(979 Views)
Thank you but this did not work on a Windows 10 machine.  Do I need to go to W11?
(883 Views)
No, it should work on Windows 10 as well, regardless of the operating system. You did something wrong, perhaps through a mistyping...
(873 Views)
Can you post both the INI file you used that didn't work, as well as a screenshot of the place in you go where it "doesn't work"?
Also, do you have multiple instances of LabVIEW on your PC by chance?  Either different "year" versions or different bitness versions?  It would need to be applied to all of them, if so.
(869 Views)
I have a 64 core, 128 logical, Ryzen Threadripper.  I added the line ParallelLoop.MaxNumLoopInstances=256 to my .INI file (LV2023).  When I then go into the ParFor loop configuration screen, I am able to up the number of instances from 64 to 128, which I was not able to do before - so that part worked.  But when I ran my code and looked at the performance in the task manager - only half (64) of the logical processors where being used.
(842 Views)
