multiple input labview 7.1
Hi there,
I am new in labveiw, but i tried to make some programm to open  multiple data file in single graph screen, but it is not working.
what i want to do..in each text file there is Amplitude and phase value. i want to compare minimum 4 text file in one screen.
i also want to substract two data files and see the difference between various taxt file.
can any body help me in that it will be great help
thanx in advance
raj
(3,909 Views)
Hi raj,
you can use the "read from spreadsheet file" function to read your data. Then use the index array function to read both sub arrays with your values to work with it.
Mike
(3,896 Views)
Hi raj,
see the attached picture, please. It shows an example of what i meant.
Mike
(3,893 Views)
Hi Mike,
Thanx for reply.
i have created program as you send me in picture, but somehow i am not able to run it, can you please check it
Thanks in advance
raj
(3,874 Views)
Hi mike,
I got solution but i want to see 5 or 6 text file at a time on a singel screen, and each file hase minimum two data (amplitude, phase..etc)
how can i do that with this?
(3,873 Views)
Sorry previously it was wrong one,
This is correct one...how i can see 5 text file at a time one one screen on the same scale? because i need it to compare all the data, please give me solution.
Thanx in advance
raj
(3,871 Views)
Accepted by topic author rajaryan1984
Hi raj,
something like in the attached example should work for you. It's an example where all your file are in one folder.
Hope it helps.
Mike
(3,858 Views)
