multiple if...else - is case the only solution?
Hi guys,
I need to create a VI with if-else statements. The problem is that there is 5 such cases. Is there any better solution than using nested cases structure?
To be specific, I want to set a certain wait time for a timer for different input frequencies, ie:
if frequency <500 then time = 3000 ms
if 500<= frequency < 1000 then time = 2500 ms
if 1000 <= frequency <5000 then time = 3000 ms
and so on, I will get probably up to ten such ranges.
I would appreciate any idea! 10 nested cases would look rather silly...
Message 1 of 10
(7,507 Views)
Accepted by MsEngineer
you can wire the numeric value directly to the case selector and set a number of ranges (don't forget to set a default case)
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/structures/case-structure.html
https://www.ni.com/docs/en-US/bundle/labview/page/entering-values-for-each-case-structure-subdiagram...
__________________
Engage! using LV2015
Message 2 of 10
(7,502 Views)
The case structure can accept booleans (and error clusters), numbers (integers), strings, and enums to its case selector tunnel.  In your case, a number.  And you can have ranges too.  So your cases will be "..499", "500..1000", etc.
Message 3 of 10
(7,462 Views)
I've done something like this if I expected the values to change:
(As shown, this makes the case statement also able to process floating point numbers, but is a little less self-documenting.)
You can also use Boolean Array to Number instead of the 1D Search Array, but I feel my method is a bit easier to understand.  I will often use code that seems more straightforward but less optimized to more clearly show what is happening if I feel the performance hit is negligible.  It is my thought process that creating developer-friendly code helps make it easy to maintain.
Bill
CLD
(Mid-Level minion.)
Message 4 of 10
(7,449 Views)
If you do use the boolean array to number, changing the radix view on the case structure to be binary helps sort out what case will be called.  But I agree that it still isn't very readable.
Message 5 of 10
(7,405 Views)
Thanks, it works and looks good!
Message 6 of 10
(7,392 Views)
Personally, I would just threshold into an array of frequencies and use the correctly rounded output to index into an array of times. No case structure needed. 🙂
Message 7 of 10
(7,373 Views)
That's because you don't play fair.  😉
Bill
CLD
(Mid-Level minion.)
Message 8 of 10
(7,363 Views)
Fair enough. 😄
Here's how it could look like. Easily expandable by just adding elements to the array constants. No code changes needed and everything visible at all times. (adding cases to a case structure is much more work, hides more and more code, and is also error prone!). Note that the array of frequencies needs to be sorted, of course.
The code might need to be tweaked depending if you want to include the boundaries into the lower or upper range, so modify as needed. Of course boundaries in DBL are not necessarily what you think they are, so be careful)
Message 9 of 10
(7,339 Views)
@altenbach wrote:
Fair enough. 😄
I am ALWAYS learning stuff from you.  Thank you!
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(7,248 Views)
