multiple file reading and 3d graph
Hi
I build this vi to read in multiple .txt files and plot them all in a 3d graph. Problem is only the last loaded file is plotted, and not all of them in "angle of reflection" (y-axis) continuously.
Message 1 of 9
(3,708 Views)
sorry, double post, can some admin delete one of them?
thanks
Robert
Message 2 of 9
(3,701 Views)
Your 'Load Data' vi is only reading in the first of the files. You must do something like the attached to read in all of the files.
Randall Pursley
Message 3 of 9
(3,699 Views)
if i use a for-loop, the data-stream will be 3d but all rows only accepts 2d?
Message 4 of 9
(3,691 Views)
I changed numerical to array, but i still have this type-error 2d <-> 3d with the graph and the write I/O ?
Message 5 of 9
(3,687 Views)
does somebody know how I can get a 3d array ionto a 3d graph without loosing information?
Message 6 of 9
(3,670 Views)
Ok, now I get them all presented one after the other, but I would like to have each new one at a new y-coordinate, any hints?
Message 7 of 9
(3,666 Views)
can you post two or three files, which you would like to read?
I am testing your program but i have problems with the files.
Markus Weigl
NI
Message 8 of 9
(3,647 Views)
Markus,
Make sure to check the other thread here where I think I addressed Robert's question and advised him to avoid creating duplicate threads for a single issue.
Best Regards,
John
Message 9 of 9
(3,632 Views)
