multiple counters
We are using a 6602 board and would like to do buffered counting on
three counters. As this board does not allow multiple counters in a
group, we have modified the example 'Single Buffered Event Counting-Adv
(NIO-TIO)' by adding two additional sets of the counter subVI's (group
config, buffer config, set attribute, control, read buffer). We are
using the internal timebase and have the gate connected to pin 38 on a
SCB-68. When the program is run, counters 0 and 2 will count while
counter 1 does not. We are getting an error code 10123 in the counter
control for counter #1. Does anyone know what the problem might be?
Also is it necessary to be wired to each counter's gate pin on the SCB?
Additionally, we would like to write the buffered da
ta to a binary file
and are having trouble figuring which vi to use. We are currently using
Write File+ (I16) which is giving us errors.
Thanks in advance,
Kristie Elam
(2,663 Views)
post your example code.
Stu
Stu
(2,663 Views)
