multiple channels, multiple waveform graph
Hello, there! I am trying to read four signals from four channels on DAQ device. I need to show the first two signals on one diagram and the other two on another diagram. So I wrote a simple VI as I attached. It gives me an error message like the picture I attached. Does anyone know how to debug this VI? I have come up with some very stupid idea to solve this problem, I can wire all this four AI Voltage VI together then go through Timing VI, then Logging VI, then Read VI, then I can connect the data terminal of this Read VI to an Index Array VI, so that I can do the following as the third Pic I attched. I have not tried this yet, but I want to find out some better method. (Maybe like the VI I wrote, it is very intuitive for people to understand)
(2,844 Views)
Oh,,, forgot to say: Thank you for any help and suggestions! Cat Tongue
(2,840 Views)
I have modified the VI to perform continous data aquisition, the error could be due to continuous starting and stopping of the task.
you may want to refer this link
http://digital.ni.com/public.nsf/allkb/485201B647950BF886257537006CEB89
(2,825 Views)
Hello, NaruF1, I rerun the program as you modified. It gives me the same error message. Please see the picture I attached. Thanks
(2,804 Views)
We need more information on detail of the DAQ device in use? I suspect this error could be due to sharing of single onboard clock.
However, If all the channels could be coupled into a single task (This should be possible since there are not configuration difference between acquisition for different channel)
Then you could use the Simple Delete from Array Function with Index=2 and length =2 available to seperate the waveform array and display them on two seperate graph Indicator. (attached modified vi)
(2,772 Views)
(2,755 Views)
