multilist box with decimal format
I defined a global array of cluster "Test Results" with all the parameters I needed to log and created a user event which triggers when the data needs to be logged. Though I created the pressure flow rate and vacuum flow rate as a double when I write it to list box or a .csv file I see the rounded value. I tried %d or %f instead %s but still I get a rounded value. But when I checked my global variable "Test Results"those parameters are double. Any help is appreciated.
(2,853 Views)
did you check the CSV file by opening in excel and formatting the cell to display decimal values?
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(2,850 Views)
Thanks Anil. Yes I did that and it is in right format.
(2,838 Views)
Accepted by romesh
romesh, remove the . in the format specifier or place a value after the .
the format specifier %.f will be read as %.0f which will have no places after the decimal point.  If you need 2 places use %.2f.  That should fix the problem.
Troy.
Troy
(2,823 Views)
