multicolumn listbox header
Hi! I have a question about multicolumn listboxes. Is it possible to arrange vertically the header string in the multicolumn listbox?
Thank you for your help!
Ákos
(4,085 Views)
Accepted by akos.zoltai
You can make the row headers visible and make the column headers invisible. Right click on the multicolumn lisbox in the front panel and go to Visible Items to do this. If you want to stack the letters on the column headers, you will have to enable the column headers to allow multi-line input and add one letter for each line.
(4,081 Views)
Go into the properties (right-click), and select show row headers.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,079 Views)
