moving elements from array to array
From the front panel I right click on the expectancy element in each array and changed the representation to I32. But I still got the same problem.
Message 81 of 84
(955 Views)
  • Did you change the diagram cluster constant too? How about the subVI connectors?
  • Do you still see coercion dots?
  • What type does it say in the context help if you hover over any of the relevant wires?
Message 82 of 84
(951 Views)
This is how it is now, but how can i change the diagram cluster constant to I32
Message 83 of 84
(934 Views)
Right-click element...representation...pick
(You did not do anything new and there are still at least nine red coercion dots. In every instance, the compiler is telling you that there is a mismatch in type. Very few should be left! How much do you know about datatypes?)
Message 84 of 84
(928 Views)
