moving cube with accelerometer data
I would like to know if a library exist to moving a 3D cube with data come from an accelerometer (3 axes)?
I don't know can I make this vi because there is the time to take into consideration.
If a person know to make a vi or a library, please help me!
Thomas Muller
(4,919 Views)
Hi Thomas,
Thanks for posting here. Let's see this threads : cube.vi3D control, 3D cube llb...
With cube.vi, you can control in 3D  you three axes XYZ with numerics datas.
So if you are using DAQmx functions (or DAQ assistant), you can acquire these values and put them into the cube.vi as entries.
Then, you will have an empirist-testing time in order to set your project properly.
Message Edité par jp_Braud le 06-20-2007 04:41 AM
BRAUD Jean-Philippe
Field Sales Engineer - Nord et Centre France
LabVIEW Certified Developper
(4,900 Views)
Maybe you could start with the bouncing cube example file. I've always liked that one.
(4,887 Views)
Thanks for your reply.
I have already try to start with the buncing cube but I'dont make it.
I'll try again but I think it's more difficult that send data to the buncing cube vi.
Thanks again and if you have solutions please reply to this message.
(4,863 Views)
Post some of your data so we can see the format.
(4,859 Views)
Thanks for your help.
I have a  lvm file with one acceleration and the time, but if the cube moving on this axe, It's win.
I think there is many persons that the vi can be interrested.
(4,853 Views)
