movement On dani
Sorry, I was getting constantly, while I was downloading the example from the labView help, an error that says something like the file ....Vishay TSOP853 Series can not be found. I try to look for it but neither I cold find it.
Thank you.
manolo
Message 21 of 30
(2,271 Views)
The Vishay TSOP853 is an IR distance sensor, which I believe is on DaNI 2.0, while DaNI 1.0 has a PING))) sensor.  You may have downloaded the 2.0 example.
Message 22 of 30
(2,271 Views)
Thank you. I will retry.
What about the code?
Thank you.
manolo
Message 23 of 30
(2,271 Views)
good morning Karl,
could you take a look at the code I sent to you?
thank you.
manolo
Message 24 of 30
(2,271 Views)
It looks like the code should cause the robot to keep driving forever.  So in that sense, it looks fine.  If you want it to only drive for a set distance, you'll need to add some code to read the encoders to check the distance traveled.
Message 25 of 30
(2,271 Views)
Good morning Karl,
That is exactly what I think,  problem is that I get a broken arrow!!
Thank you.
manolo
Message 26 of 30
(2,271 Views)
What error do you get?
Message 27 of 30
(2,271 Views)
there is a list of them.
thank you.
manolo
Message 28 of 30
(2,271 Views)
I don't know why you're getting those errors.  You may want to contact support. www.ni.com/support
Message 29 of 30
(2,271 Views)
I wil try,
thank you.
m anolo
Message 30 of 30
(2,271 Views)
