move image up down
Hi all I want to build code in labview that move image up and down while change value , does any build or design Any this like that before  I will be very thankful to know thanks
(4,827 Views)
quick search
also see here
Message Edited by mathan on 10-29-2008 04:30 AM
(4,823 Views)
mathan wrote:
quick search
The first link from mathan points to a thread where Mike Porter suggested customizing a slider is the simplest solution and if it meets your needs is what I would recomend. (Thanks mathan!).
But if that does not meet your needs then the fall back position is to use the LV Picture control. This thread has links to Picture Control Examples and may be of use if all else falls short.
Ben
(4,805 Views)
Thanks for the link ben. very useful and interesting.
[Edit: I didn't expect such a thread in breakpoint forum.]
Message Edited by mathan on 10-29-2008 07:47 AM
(4,803 Views)
Played a little bit with decorations, and got following trouble:
Bug or feature? 😉
Andrey.
Message Edited by Andrey Dmitriev on 10-29-2008 04:02 PM
(4,778 Views)
