mouse scroll zooming
How could I programmatically zoom in/out graph using mouse scroll?
I'm using Labview 2009 SP1
Yasemin Barutçu
Electrical And Electronics Engineer
(3,818 Views)
Use the VIs from the Input Device Control palette. The Acquire Input Data.vi returns the Scrolling Information of the Mouse wheel. You can then use this to set the XScale.Range.Maximum and Minimum property of the Graph via Property nodes. E.g.:
Christian
(3,798 Views)
Thank you this works fine and I got help from here too.
http://forums.ni.com/t5/LabVIEW/Mouse-wheel-scroll-event-ON-CHANGE/td-p/860112/page/2
"Scroll Event V2.zip"
Yasemin Barutçu
(3,793 Views)
