Mouse wheel scroll event ON CHANGE?
daveTW wrote:
I discovered your VIs today and I want to tell you, I think it's excellent work. Congratulations!
Hi Dave,
Can you pl post the link to Mike's VIs?
- Partha ( CLD until Oct 2027 🙂 )
Message 11 of 25
(7,619 Views)
parthabe wrote:
Hi Dave,
I think he is referring to the second post of this same thread Partha. See he had kudoed Mike's post. But its just my thought Smiley Wink he has to confirm this. Smiley Sad
Mathan
Message 12 of 25
(7,617 Views)
I meant the only VIs posted in this thread (so far). Smiley Happy
greets, Dave
Greets, Dave
Message 13 of 25
(7,597 Views)
for all who are interested attached is the second version of my Scroll vi's. Now it's working without polling. It reacts on the messages which will be send if the scrollwheel will be used. I use the Windows Message Library to receive the messages. The attached zip files contain an Example which shows how it can be used. If someone want to scroll through a table or an array, then please see the Vi's from version one, because they are not part of this library.
Hope it helps someone.
The vi's are for LV7.1.
Mike
Message 14 of 25
(7,408 Views)
Hi Mike,
It looks great! Unfortunately it's broken on 64 bit systems. Could you post source code of the DLL, or a 64 bit version?
Thanks a lot
Charles
Message 15 of 25
(6,819 Views)
Hi CharlesB64,
sorry, i can't send the source code of the dll. It's a dll shipped with the OS. In my case WinXP.
All vi's should be without any password, so you should be able to see everything i have done.
Edit: ohh, this dll is not from me. It's part of the windows message library.
Mike
Message 16 of 25
(6,811 Views)
Nevermind, I'll use the first version, still works in 64 bit. Great work anyway!!
Best
Charles
Message 17 of 25
(6,782 Views)
Hello MikeS81
I want use the wheel mouse to scroll an array of clusters and both of your "code versions" can do the trick. Which one should I use for that? What are the advantages and disadvantages of each one?
I have ScrollEvent_LV71.zip and Scroll_Event_V2.zip
Thanks.
Dan07.
Message 18 of 25
(6,372 Views)
Hi Dan07,
you can use both versions. The advantage of the second version is that it works without polling, it reacts on windows messages. The disadvantages of the second version are, it runs not on 64 bit operating systems and it is usable on windows only.
Hope that helps.
Mike
Message 19 of 25
(6,340 Views)
Hi MikeS81,
Great work! Is there a reason for the passwords in the first version? I have a Windows 7 64bit OS and can't use the second version, so I'd like to use your first version and modifiy some vis. I would be very happy to be able to look also into the password-protected ones. Thank you very much for sharing!!
Message 20 of 25
(6,263 Views)
