mouse over menu bar stops program execution
Hi
I am using a menu, but Every time I move my mouse over a menu, my program halts. I use the vi 'Get Menu selection' (Application control -> Menu -> Get Menu Selection). Even if I use an Event structure to obtain the menu tags, I get the same problem. This problem seems to be the same in the standard examples in labview.
Is there any way I can use the menu bar without it interrupting the main program?
Many Thanks,
Thijs
(2,770 Views)
Problem solved...using a very short time-out value in a event structure and a bug solved in my main program.
Thanks, Thijs
(2,756 Views)
