monitor size will be a problem?
Dear all,
Am developing a application using mouse-events. I generate some click events on some particular controls automatically. So if i use that particular application in some other system with a different monitor size will there be any problem?
Earlier response is much appreciated.
Mathan
Message 1 of 27
(4,196 Views)
Hi mathan,
i think it depends on how you have designed your program. With fixed x and y values it could be a problem.
Mike
Message 2 of 27
(4,175 Views)
Hai mike,
Yes i have used user32.dll (mouse_event function) and specific x,y coordinates to generate click events on controls. So it seems it will definitely be a problem? Any remedies?
Mathan
Message 3 of 27
(4,171 Views)
Hi mathan,
you can get the x, y coordinate of the specified window and add the position of the object in this window to the window coordinates. I think this should work with every monitor.
Mike
Message 4 of 27
(4,158 Views)
Hai mike,
Thanks. Could u please give a sample structure for that case.
Mathan
Message 5 of 27
(4,142 Views)
Accepted by Mathan
Hi mathan,
with the user32.dll function "GetWindowRect" you can read the position of the window, on which you want create an event. To this position you can add the position to where you want to move the mouse. The attached example shows hao to get the coordinate of the specified window.
Why do you use the x and y positions? You can send a key pressed to a specified button without moving the mouse to this position.
Mike
Message 6 of 27
(4,131 Views)
Hai mike,
Thanks. But, that's not at all a problem.
Mike
I can send a key press to the specific button without moving the mouse to its position, but the thing is i have to generate the click action not in LabVIEW but with other window application. That's why am using x and y positions eventhough its not efficient.
Mathan
Message 7 of 27
(4,124 Views)
Hi mathan,
what is the problem? Smiley Happy
Mike
Message 8 of 27
(4,117 Views)
Hi Guys
I need to use user32.dll for controlling my mouse events. I am able to call the dll & specific function of using "Call Library Function Node".
My Problem is that i am not able to get any information on what is the particular prototypes of specific Functions.
Where can i find all prototypes of all functions in a particular dll? I already tried http://msdn.microsoft.com/en-us/library/.
Thanks & Regards,
Rajan
Message 9 of 27
(3,989 Views)
Hi Rajan_77,
you can use "depends" or the LabView function to get all exported dll functions. If you have them, you find a lot of information with google or in msdn.
Which function do you want to use from the user32.dll? For moue events, you can also use the input vi´s from LabView.
Hope it helps.
Mike
Message 10 of 27
(3,979 Views)
