monitor independent front panel
HI,
I developed application for a 1440x900 monitor resolution.
when i installed this application in other monitors with different resolution, the front panel objects were misaligned.
how to make front panel independent of monitor or resolution.
Thankyou,
hari krishna.k
(2,336 Views)
By checking this check boxes,you can minimize the re alignment issue
AB
Kudos are Accepted
(2,327 Views)
