modifying a sub vi.
When I place the attach vi into another vi, there is no output for Par Angle. What the easiest way to make this an output of the vi.
(2,983 Views)
I can't open your VI, but I think you have to connect your indicator to the connector pane. Click right on the left top corner (icon) in the block diagramm and select "show connector pane".
(2,980 Views)
Change your connector pattern to a 4-2-2-4 (which is considered a good standard by most LV style guides).  Then connect one of the other connector terminals to Par.  See attached.
Message Edited by Ravens Fan on 01-30-2008 11:02 AM
(2,978 Views)
Thanks guys.
(2,956 Views)
