Graph Boolean
I want to graph the pulse output generation an the input. If you take a look at what I have done, you will see that I have used DAQ Assistant to acquire data and generate the pulse. I want both the input coming in (at source 0) and the output (Out 1). How can that be done. As you can see in the example that I have tried to generate the output in waveform but this is not what I want. I have read all the posts but it comes down to the array problem and the graph is not continious. I looked at the LABView examples but couldnt do much. Please help.
(2,915 Views)
Any takers? Anyone has a suggestion? I am really stuck!
(2,895 Views)
