missing QuitLabView function
Hi!
I cannot find the QuitLabView function in my palettes. How can I install it?!
I am using LabView Professional Development System, version 19.0.1f1 (32-bit) on  Windows 10 Education, version 1803.
I have already uninstalled LabView, download a new installation file and re-installed it, but I got the same...
Thank you for your help,
Best Regards,
Francesco
Message 1 of 8
(4,230 Views)
Odd that it is missing.
But is there a reason you need to use it?
I have never, ever needed to use that or the Stop LabVIEW function in any of my VI's.
If I'm in development environment, I don't ever want a VI shutting down the whole environment.  If I'm creating a built exe application, then I write it so that it wraps up all loops and running subVI"s nicely, and as a final step before execution stops, closes the front panel.
Message 2 of 8
(4,193 Views)
Hi fmessi,
what happens when you open QuickDrop and type "Exit" or "Quit"?
(There's more missing items from the palette compared to my LV2019 installation…)
Message 3 of 8
(4,190 Views)
You are also missing a couple of other things. Compare with my LV2019 palette:application control.png
You are missing Get Command Line ..., Get Drag Drop Data, Application Builder too.
Certified LabVIEW Architect
Message 4 of 8
(4,122 Views)
Maybe a complete wipe and reinstall will help, I'm not sure. Or try installing on a VM to see that it works as expected first.
Message 5 of 8
(4,120 Views)
I agree with you, RavensFan, but I am using (or would like to use) the One-Wire utilities from Interfaceinnovations and they are using it... so I can't run anything without QuitLabView
Message 6 of 8
(4,108 Views)
I have tried to uninstall everything (from NI Package Manager) and reinstall from a new download... didn't work, same situation...
Message 7 of 8
(4,106 Views)
Something is very wrong here.
Any chance you have a user directory on a network share or something like that? Anything that is different from a 'normal' windows installation?
Message 8 of 8
(4,091 Views)
