missing LabVIEW MathScript commands for control systems
I'm watching these:
They are about control system engineering with LabVIEW.
I have LabVIEW 2015 with the MathScript RT and a test license for Control and Simulation library.  I also have a licensed MatLab installed, but it does not have the control system toolboxes.
They both use the "ss" command in MathScript.  I can't find it.  I get errors.  I search in help and it is not there.  It is not in the examples.  When I look at the Block diagram VI's from the scond video I have substantially fewer controls on mine.  I get PID, Fuzzy, and System Identification.  I don't have "SISO".
I have several guesses as to what is wrong:
  • it was removed from the MathScript RT module.
  • I need a different toolkit or demo.
  • it has a new name that is non-intuitive.
Can you help me find the "ss" command so I can duplicate what they are doing?
(6,286 Views)
- LabVIEW Control Design and Simulation Module toolkit : http://www.ni.com/labview/cd-sim/
- you can download evaluation version and try.
- what you have is LabVIEW MathScript RT Module http://www.ni.com/labview/mathscript/
- As per my knowledge in MATLAB also it is separate toolbox which is licensed separately.
- For LabVIEW Control Design and Simulation Resources : http://www.ni.com/tutorial/11653/en/
uday
(6,269 Views)
@udka - I must have installed something wrongly.  I tried again, and it still doesn't have the menus, or the updated command-set in MathScript RT.
The system knows some commands, but not enough to do a basic step response.  I have 2015, not 2016, and I already had MathScript RT.  I'm thinking that the mismatch has to be in that area.  I could be wrong.
(6,167 Views)
From the screenshot of the palettes, it looks like the Control Design & Simulation toolkit either isn't installed or licensed correctly - you should have a whole bunch of simulation palettes etc.
From what I recall, the PID / Fuzzy toolkits are separate from the main CD&S toolkit.
Can you show us what you have installed under 'software' in NI MAX? Perhaps also show us your NI license manager.
(blog)
(6,155 Views)
Here is software from NiMAX.
Here is most of license.
(6,142 Views)
Accepted by EngrStudent
You have installed the wrong version of the Control Design and Simulation module - the version must match the version of LabVIEW (i.e. 2015, in your case).
Download/install the older version and you should be good to go.
(blog)
(6,086 Views)
