microsoft graph location
Hi, I am still struggling with the report generator. I finally managed to generate a table, and now I want to try inserting a graph into word. The error I get is: "No such interface supported in Word Module.vi->Word Insert Graph.vi->test_reg_gen2.vi" with test_reg_gen2.vi my application.
I do not know what this error means, but I have been looking for MS Graph. I work on NT4 with Office97 and Labview6.0.2. Seems that I use MS Graph 8.0, but according to microsoft, the location should be somewhere in 'Commom files', allthough this is not where I found it, but in the office install directory. Does anybody know how I can tell labview where the exact location is?
Or does anybody knows what the problem really is?
Thanks.
(2,799 Views)
It doesn't matter where msoffice is installed, the report toolkit uses activeX so as long as it is registered with the system, LabVIEW should find it.
You should talk to support on this one but if you're in the experimenting mood i found this article in NI's support site: http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/09587a20698a5482862565b500516199?OpenDocument
The above article is related to Word but it's not unlikly that Excel suffers from the same.
Michael Aivaliotis
VI Shots LLC
(2,799 Views)
